new issue *now that idle fixed lol
Old Apr 27, 2014 | 07:02 AM
  #21
Cut the hoses off the heater core and get new ones.
If you are replacing the alt belt - yes the others have to come off.
Please explain more about these "two 14mm bolts off the alt bracket"?
Old Apr 28, 2014 | 11:38 AM
  #22
huntersdl's Avatar
The swivel bracket the alternator was attached to where I had to rock it back and forth. Its attached to the engine or something with two 14mmi bolts. The bracket is in the way of me pulling the alternator down to the axle...book says to remove it too
Old Apr 30, 2014 | 08:19 PM
  #23
huntersdl's Avatar
Poorman.. know what im referring to? Ive read its allegedly optional but I couldnt get it past that bracket
Old May 1, 2014 | 05:11 PM
  #24
Again, I've changed somewhere around six or seven of these. I've never pulled the cv shaft and I have never removed that lower bracket (I'm assuming that is the one - the upper has smaller bolts).
If you are having trouble getting the alt from the lower bracket - get a big/long screw driver or pry bar and put it between the alt and that bracket (engine side) and pry on it as you rock the alt towards the front and back of the car.
Then - again just me, slide that bad boy along the firewall towards the pass side and then pull it from where those heater hoses go to the heater core.
Old May 1, 2014 | 05:54 PM
  #25
huntersdl's Avatar
Default alt
oh i have the alternator loose.. i just cant get it to fall out from that area... cant get it past the bracket.. i have tried turning it diff directions and maybe i have missed an angle.
Old May 3, 2014 | 08:23 AM
  #26
Pull, push, move it towards the firewall in an almost straight/level move. Once you have it at the firewall there is enough room to start to spin/twist it in a way that it will either move along the firewall to the pass side and remove from there or since you already pulled the cv shaft - drop it down.
slammed accord
May 25, 2012 08:18 PM
HondaPhyco
Apr 15, 2008 10:27 AM
Jay 3rd
Mar 16, 2008 12:02 PM
mig25
May 24, 2007 03:50 PM
otherhonda
Dec 7, 2006 08:16 PM
