No Spark-No Fuel HUH
Old Dec 21, 2007 | 08:14 PM
toddyfresh's Avatar
Default No Spark-No Fuel HUH
I have a 94 accord ex and it was running good. i had it started went to work come home and when i went to go somewhere again it wouldnt start. I couldnt hear the fuel pump kick on and i checked spark none. SO no fuel pump and no spark i checked fuses anybody know anything?
Old Dec 22, 2007 | 12:03 AM
Default RE: No Spark-No Fuel HUH
If you don't have voltage at the black/yellow wire going to the distributor, suspect a bad ignition switch (the electrical portion).
Old Dec 22, 2007 | 10:31 AM
sir_nasty's Avatar
I'd also check the main relay just to be certain. Is the battery connected well and the connections clean? does the car try to turn over at all?
Old Dec 22, 2007 | 04:00 PM
ORIGINAL: toddyfresh
Replace the coils and then see if she starts up...
Old Dec 22, 2007 | 07:11 PM
toddyfresh's Avatar
yeah turns over fine just wnot start up. i dont believe coils are problem it has no sparke and no fuel both at same time replacing cois would be waste of money
Old Dec 23, 2007 | 12:39 PM
Neke1point0
since the car is turning over id resistance check the coil per the helms specs. if i remeber right it isprongs num2 and 4on the coil and then the side going to the dizzy. the resistance i think its < .08 ohms. and since ull have the ohm meter there test the dizzy wires as mentioned above too. i just recently had the sameprob,my coil and dizzy went at the same time. GL, hopefully ts just the coil.
Old Dec 29, 2007 | 01:43 PM
HondatechAV6's Avatar
fuel main relay. controls fuel and spark. easiest way out.
Robert Leach
Mar 22, 2014 10:12 AM
sirtwist2
Sep 24, 2012 01:36 AM
BigOBob
Jan 1, 2012 02:47 PM
SeanAccord
May 18, 2010 08:24 PM
finch13
Oct 17, 2007 02:45 PM
