obdII problem?
Old Dec 14, 2012 | 09:14 AM
redrum's Avatar
Default obdII problem?
The other day i installed a clifford smart start on my 09 ex-l. As soon as i started my car after the install my vsa light and a triangle with an ! Came on as well. I didnt get a chance to put a scanner on it but planned on it. A few days later i installed my ram air intake and the cel came on. I put a large snap on scanner on it and it said that it could not communicate with the car. When i put a basic code reader on it, it said no faultz present. So basically some how my car has all of these lights on it and i cant hook any scanner up to the dtc port. Can someone please help give me some guidance on what may be the cause? Could i have tapped into a wire on the remote start that is causing the port to not read? I checked the fuse and it isnt blown. Any advice would be beyond greatly appreciated. Every time i start my car my eyes go straight to those lights and they are driving me crazy. Please help. Thanks in advance
Old Dec 14, 2012 | 09:44 PM
Now you are in the situation where the problem could be the add-on(s) or the wiring.
Is there a quick way to disable the remote start to see if that fixes the problem?
Check around your new intake to see if you left a ground wire disconnected or damaged some other wiring.
h22a1-96
Feb 2, 2010 10:01 AM
tqriddle
Aug 24, 2009 10:23 PM
tqriddle
Aug 22, 2009 05:14 PM
usaccordinjapan
Dec 17, 2008 06:12 PM
pjlooby
Dec 19, 2007 07:49 PM
