Odd Shake when driving
Old Nov 17, 2007 | 10:55 PM
10th dude
Default Odd Shake when driving
I have a 199310th anniv. 118,000 miles. Over the past couple of years when driving ant any speed the enigine/front end will shake & shudder off and on, not constant or anything. If you let off or give it gas it will quit doing it. The plugs and cap & rotor are new less than a few thousand miles and were changed to see if that was it, no luck. Anyone else have an idea!!
10th Dude
Old Nov 18, 2007 | 08:43 AM
deserthonda's Avatar
Default RE: Odd Shake when driving
does it feel like engine or suspension ?? steering wheel shakes ? chk tires+ frt suspension components., shake also going at 15-25 mph? as well as hwy speeds ? 5sp or AT tranny ? chk engine lite on ?
Old Nov 18, 2007 | 05:28 PM
Chiovnidca's Avatar
Pull off the vacuum line to the egr valve and take it for a drive. Does it still do it?
Old Nov 18, 2007 | 05:39 PM
Over a two year period of this shakeing! Have you changed or rotated your tires....
Old Nov 18, 2007 | 09:23 PM
SteveO_f22a's Avatar
my 92 EX shakes at about 80-85. always done it. i heard that its just one of those things that 4bangers do at that rpm, but im not sure if my sources are correct. nothing has gone wrong with my car. i got about 220k miles.
Old Nov 29, 2007 | 10:15 PM
10th dude
No, not the tires, could be vac line, if feels like either the engine, or tranny, or maybe the rack, which was replaced some 40,000 miles ago,due to slack or somthing according to the dealer. it has puzzled me for the longest time, because it is so intermitent.
10th dude
Old Nov 30, 2007 | 04:24 AM
HondatechAV6's Avatar
i'm leaning toward an egr problem. this can be intermittent or very consistant. i'm leaning toward pluged egr ports. since cylinder 1 is farthest from the egr valve it will clogg up last. so cyl. 4 cloggs, then 3, then 2, then 1. typically you'll get a misfire when on 1 when it's very bad. so i'd guess cyl 4 3 and possibly 2 have restricted ports.
in addition, this problem should usually only happen on light acceleration between 1500-2000 rpm.
to diagnose this, with the engine running apply 10" vacuum to the egr valve vacuum port. the engine should die. if it doesn't, get ready to clean!
to clean the egr ports(6 in total)you need to drill into them, tap them, install a bolt, use a mini slide hammer to remove them, and then clean the port, install new caps and replace the egr valve.
have fun!!
ORIGINAL: SteveO_f22a
here i'd suspect unbalanced tires or one or both balancer shaft timing being off. it depends on the vibration. it should be silky smooth.
JackP
Oct 15, 2007 10:28 PM
ssc280
Apr 27, 2007 10:13 PM
92Inspire
Aug 8, 2006 04:07 AM
wth71
Jun 29, 2005 03:02 PM
