odd sound when I let off the gas...
Old Oct 9, 2012 | 11:26 PM
ScanMan90's Avatar
Default odd sound when I let off the gas...
So I've been hearing this sound for a while now. When I let off the gas at certain speeds(usually over 40 mph) I hear an "errr" kind of sound. There's also a rattling that sounds almost like a loose heat shield. Btw, my heat shield fell off a while back. I'm not quite sure what it is. Maybe motor mounts? Just curious if this is a common problem because it's starting to annoy me lol the car is a 96 Accord LX 2.2L auto trans. Thanks!
Old Oct 9, 2012 | 11:54 PM
See if the symptoms are similar to this technical service bulletin, which may be due to worn mid-pipe gaskets and/or exhaust pipe hangers.
Honda TSB 94-041
Old Oct 10, 2012 | 12:02 AM
ScanMan90's Avatar
ahhh yes. that could be it. I'll check it as soon as I get the chance. thanks!
Old Oct 10, 2012 | 06:42 AM
mamtsberg's Avatar
Check the exhaust for the rattling sound like your loose heat shield sounded like. Replaced my heat shield a few years back. Just had to replace flex pipe and after that I got that "heat shield rattle" ended up being the internal honeycomb in the cat converter had split apart. Bang on the converter and see if it rattles.
I head the rattle when braking, usually when coming to a stop and when just starting to accelerate, after up to speed and cruising it was fine.
thecheesyburger
Mar 10, 2014 02:07 PM
tdmitch2
Mar 2, 2008 11:43 AM
05hondaman
Jan 2, 2008 01:50 PM
05hondaman
Dec 29, 2007 10:46 AM
05hondaman
