Oil change and brake flush
Old Oct 21, 2011 | 01:47 AM
rubberducky101's Avatar
Default Oil change and brake flush
So i've decided to steer away from the dealership to a shop in Houston called m power auto specialist because of the dealership charged so much for maintenance service. I'm planning to drop off my car this tuesday and I have 2 questions:
1) they used castrol oil instead of pennzoil (which my honda dealership use), is castrol better than pennzoil?
2) i'm planning to buy honda's brake fluid for the flush but i don't know how much to get. i've only bought one 12 fl. oz. container so far. Do i need to buy more?
Old Oct 21, 2011 | 07:11 PM
Personally, I'm about to get flamed or start a debate.
Engine oil and brake fluid are not something, IMO, that have to come from the dealer.
Oil, we all have our favorite brand....as long as it is the proper weight and proper rating you will be fine.
Brake fluid the same, proper rating (DOT 3 or 4-see owners manual - 3 I think for your car, even though I don't know the year) and you will be fine.
How much, ?, def more than a pint. I think I went through well over a quart last time I did a complete flush.....of course I use Newton to change/bleed my brakes so there might have been a bit of waste in my method.....sipping coffee too long while waiting for the fluid to turn clear
EDIT: My ref to Newton is because I gravity bleed my brakes, too hard to find a helper.
Old Oct 21, 2011 | 07:29 PM
UhOh's Avatar
in the big picture, oil "betterness" perception is dependent on how much the company spends on advertizing.
Castrol spends about as much as Pennzoil, so it's a comparable grade.
I'd feel good about the change and go for it.
Old Oct 21, 2011 | 08:11 PM
bigpat's Avatar
Almost A Senior Member
I have always used Castrol GTX in my cars and motorcycles for over 30 years. Never an issue and always changed between 2500 and 3000 miles.
Old Oct 21, 2011 | 10:28 PM
PLEASE don't let this turn into a debate on oil pref....on topic.
THANKS
Old Oct 22, 2011 | 04:40 PM
Okay, thanks for the input guys. Just to make sure i'll give the guys at the shop a call to see how much brake fluid they need before i drop off my car.
coolaccord
Oct 5, 2014 11:15 PM
chris h
Apr 3, 2011 10:01 AM
redman4ever
Jan 31, 2011 04:23 PM
dtcaccord
Jun 4, 2008 09:54 PM
mrmookie123
Mar 1, 2007 10:05 PM
