Oil leak
Old Aug 1, 2008 | 04:45 PM
jerrym's Avatar
Almost A Senior Member
Default Oil leak
My new used 97 Accord, 2.2 liter appears to have an oil leak. Unable to pinpoint exactly but it appears to be coming from the area near the belts/timing belt cover.
Will degrease engine and look closer. Was wondering if anything in that area is common with leaking oil and what it takes to fix.
Thanks and TGIF!
Old Aug 1, 2008 | 09:13 PM
Default RE: Oil leak
Clean the engine thoroughly to pinpoint locate the leak(s). Most likely sources are the valve cover, distributor shaft o-ring, oil sending unit, oil pan gasket, oil pan bolt gasket, and/or the timing/balance shaft seals.
If the leak is coming from the timing belt cover, then the seals inside are the likely culprit. Unless the timing belt is soaked in oil, I would wait to change these seals until you have to change the timing belt.
alltime3rdwheel
Dec 31, 2012 10:46 AM
frost506
Jan 16, 2012 07:21 PM
MiyashiMeism
Sep 5, 2010 02:12 PM
mamtsberg
May 30, 2010 07:04 AM
xaznxeclipsex
Sep 28, 2007 02:05 PM
