oil leak
Old Mar 20, 2015 | 04:56 PM
hondaccordguy718's Avatar
Default oil leak
Check these pics out. I'm thinking a leaking valve cover gasket, but what's with the oil all over the alternator? Car is not overheating, but burning smell coming from engine.
Attached Thumbnails oil leak-car1.jpg   oil leak-car2.jpg   oil leak-car3.jpg   oil leak-car6.jpg   oil leak-car4.jpg
Old Mar 20, 2015 | 06:30 PM
Looks like possibly several leaks; distributor shaft/head oring, valve cover gasket, PS pump (Looks minor).
New valve cover gasket kit, new distributor shaft/head oring.
Old Mar 20, 2015 | 06:47 PM
Thank you!
I had a crank, no start situation a week ago. Car had to be towed, then it started fine the next day for no reason. Couldn't find anything wrong so just replaced the main relay. Is is possible the distributor was not working right because of the leak?
Old Mar 20, 2015 | 07:22 PM
Unlikely, your leak should not affect distributor firing.
When no-start occrus again, check whether fuel pump comes on (fuel pump buzz from fuel tank) for 2-3 secs when keyswitch is turned to On, and goes off. If not, fuel delivery is problem; main fuel relay or fuel pump.
Old Mar 20, 2015 | 07:35 PM
TexasHonda, I took this car to a mechanic to figure out the no start issue and I also had him do an oil change since it was there already a few days ago. He didn't mention a word about me leaking all this oil. Is he blind? Or is this really not that big of deal? This oil was obviously all there a few days ago(it's caked on old and thick). How come he didn't mention this?
Old Mar 20, 2015 | 10:33 PM
Probably because he's seen much worse on similar age cars. Oil leaks are not rare.
alltime3rdwheel
Dec 31, 2012 10:46 AM
frost506
Jan 16, 2012 07:21 PM
MiyashiMeism
Sep 5, 2010 02:12 PM
mamtsberg
May 30, 2010 07:04 AM
xaznxeclipsex
Sep 28, 2007 02:05 PM
