Oil on my plugs...
Old Jul 30, 2011 | 12:45 PM
the cyclops's Avatar
Default Oil on my plugs...
Checked my plugs the other day just to see what the previous owner was running (Bosch platinum) and noticed a little oil on the spark side of the plugs.From all accounts and receipts car seemed VERY well maintained and serviced regularly.No running problems that I can tell of,it has good power,no sputtering or stalling,just oily plugs.This isnt normal correct?
Old Jul 30, 2011 | 03:01 PM
A search will show this is extremely common problem. New valve cover gasket kit (felpro or other) has all seals. Easy DIY, except for rocker arm orings if you have an F22B2 engine (LX, DX).
Old Jul 30, 2011 | 05:06 PM
Oh,I see...Im sorry,I will search next time.I dont believe I could do this my self,guess I will call the "import shop"on Monday.Thanks.
Old Jul 30, 2011 | 06:59 PM
You said the oil is on the "spark side" of the plugs? Do you mean below the threads, or above them? Inside the combustion chamber? What Tex said applies for oil above the threads, on the ceramic insulator.
Old Jul 30, 2011 | 10:31 PM
Yes seemed to be on the threads.
Old Jul 31, 2011 | 01:09 PM
Now looking back on it,I had difficulty getting plugs out of the hole after it was unscrewed(Kept falling out of the socket)and the threads could have easily got oily from me messing with it till I was able to pull it out,if indeed the top side area was oily.I need to pull one out I guess in one motion to see if its dirty.
WhyNotFab
Dec 6, 2006 08:20 PM
tiberius
Oct 17, 2006 11:51 PM
St3v3
May 14, 2006 04:05 AM
LinX
Feb 27, 2006 04:01 AM
hotrod20
Dec 4, 2005 11:04 PM
