oil pan gasket 94 accord
Old Dec 13, 2006 | 12:40 AM
adamc44's Avatar
Default oil pan gasket 94 accord
so sunday i went through doing routine maintenance to my car, plugs, wires, change oil, thermostat, new hoses, wiper blades, coolant flush, well when i went to change the oil i noticed the pan was leaking so i decided to change the oil pan gasket. i dropped the cross suppport bar, the exhaust, the linkage cover off the tranny, the flywheel sheild, then the pan, took the old gasket off, scraped off all the remaining gunk, cleaned the pan out, repainted the outside, then reinstalled the pan with the new gasket, well i get everythinig bolted back up and fire the car up, the gasket is starts leaking around the front of the engine near the flywheel, so i unbolt everything and unbolt the pan agian, reinstall the pan and gasket, reinstall everything else STILL LEAKING..... well frustrated i give up, so today i take everything back off, put a lot of gasket sealer on it, let it sit till tonight and fire it up, the dang thing is still leaking. what the heck could i possibly be doing wrong??? could the pan be bent???? all the bolts are tourqued acoordingly, nothings lose, the gasket is seated correclty, i dont know any honda experts and opinions on where ive screwed up would be GREATLY APPRECIATED. i really like this car and would love to be able to drive it again. thanks adam
oh my radio has a code on it, i dont have the code on the and the dealer said there should be a code on the radio, is it on the underside or the back? and where do i type in in at, where the phone is or on the radio itsself? thanks adam
Old Dec 13, 2006 | 11:00 PM
deserthonda's Avatar
Default RE: oil pan gasket 94 accord
get some honda bond from your local dealer..........also make sure that the little metal rings are not still on the studs ...make sure the block surface is clean
put some honda bond ,, lightly on the curved edge on the gasket, and on the opposite side,,,,also get some spray adhesive, spray the block and the gasket, stick the gasket on the block line up all the wholes,, Now put some Honda bond on the pan same place as you did on the gasket , install the pan..that should take care of the leak..
doing it this way i have never had any leaking problems whatsoever ,,
and last thing make sure that it is not leaking from the rear main seal ..i have seen a few of those leak
Old Dec 14, 2006 | 12:44 AM
adamc44's Avatar
ok, i will give it a shot this weekend, thanks for the help.
Old Dec 16, 2006 | 08:19 PM
adamc44's Avatar
took everything apart and applied honda bond and a brand new gasket retourqed everything and it works perfect now zero leaks. thanks for the help!!! shes back on the road!!
ccookie66
Apr 12, 2019 04:43 PM
frost506
Jan 16, 2012 07:21 PM
MichaelT1960
Mar 25, 2010 10:05 PM
tjl695
May 14, 2009 03:05 PM
Troy1988
Jun 24, 2008 05:47 PM
