Oil pan leak?
Old Sep 23, 2009 | 02:28 PM
mamtsberg's Avatar
Default Oil pan leak?
2001 Accord, 4 cyl, 5 speed.
While under the car today, changing oil and trying to repair heat shield (see other post for that one), I noticed oil residue under the car (there as a just a little before, now there is more. The car hasn't been leaking any oil (i.e. no spots on the driveway). I also noticed that where the bolts for the oil pan go in there is a "glaze" of oil almost all the way across. There doesn't seem to be any oil coming from above as I don't see any signs of leakage.
Could this just be something simple like an oil pan gasket that needs replacing?
Old Sep 23, 2009 | 02:49 PM
You're almost right, except 2001 4-cyl doesn't have an oil pan gasket. The aluminum oil pan uses HondaBond (Permatex Ultra-Grey RTV) all around the bolted edge. There's no gasket.
You'll have to un-do the exhaust pipe under the pan, so think about new gaskets for THAT piping too.
theshakes
Jul 3, 2012 07:09 AM
frost506
Jan 16, 2012 07:21 PM
mtrapuzz
Feb 28, 2010 02:44 PM
greg9442
Oct 15, 2009 10:37 AM
ricj
Jul 15, 2007 01:07 PM
