oil soaked plugs
Old Jan 10, 2010 | 09:00 PM
riverman's Avatar
Exclamation oil soaked plugs
i have a 93 accord 2.2 L with 183K miles. went to change the spark plugs and found that all of them are soaked with oil. hoq can this happen and how can i fix it?
Old Jan 11, 2010 | 10:01 AM
That's the sparkplug tube seals, basically that's part of the valve cover gasket. There's already some threads about that.
Old Jan 11, 2010 | 07:13 PM
riverman's Avatar
thank you i will read
Old Jan 11, 2010 | 07:25 PM
EXV6NIGHTHAWK's Avatar
Hopefully, it's not the o-rings under the rocker arm assembly. Those are much harder to change. If you look down the spark plug tubes, there are two seams. One for the valve cover seals, and one for the rocker arm assembly.
Old Jan 12, 2010 | 07:04 AM
Yeah, exactly. I'd change the upper seals & cross your fingers. If it still leaks, then removing the valve cover AGAIN is a very small amount of duplicated work.
Old Jan 12, 2010 | 09:27 AM
riverman's Avatar
Ok, how hard would it be to do it all at one time?
Old Jan 12, 2010 | 10:00 AM
Not much harder than doing it separately. All the real work is removing the valvegear & camshaft bearing caps. That's why you can try the valvecover gasket first. Repeating the work of removing the VC is trivial.
Old Jan 12, 2010 | 01:14 PM
deserthonda's Avatar
there is a step by step in the DIY section........here you go
https://www.hondaaccordforum.com/for...ead.php?t=3088
Old Jan 13, 2010 | 09:35 AM
riverman's Avatar
Thanks guys, looks like a day of research and read for me.
Tony Frattle
Jun 29, 2012 09:38 PM
wannakeepmy94Accord
Mar 14, 2012 08:06 PM
9foaccord
Jun 13, 2011 07:45 PM
mfre1111
Feb 7, 2008 10:44 AM
hotrod20
Dec 4, 2005 11:04 PM
