oil in spark plug tubes
Old Nov 25, 2006 | 06:16 PM
patcal's Avatar
Default oil in spark plug tubes
How do you know if the oil is coming from the big tube gaskets or the rocker o-rings? Thanks.
Old Nov 25, 2006 | 07:26 PM
drummer1279's Avatar
Default RE: oil in spark plug tubes
if you have oil coming into the spark plug tubes period its a good rule of thumb to just go ahead and replace it all to be safe.
Old Nov 25, 2006 | 07:47 PM
sir_nasty's Avatar
there is a great How To in the DIY section on replacing those as well
Old Nov 25, 2006 | 08:13 PM
patcal's Avatar
I already read the How-To. I was jsut wondering if there was a way to tell the difference. Thanks.
Old Nov 27, 2006 | 10:51 AM
deserthonda's Avatar
ORIGINAL: patcal
cannot tell ,,,,,,,so, replace the upper seals first, a lot cheaper and easier,, after a short while , chk the plug wires again , if you still see oil in them, replace the lower seals
Old Nov 27, 2006 | 11:33 AM
patcal's Avatar
Since the Felpro kit comes with the o-rings, I am going to do both while I am in there. I have multiple things that this car needs with 245K miles on it so I am trying to combine my jobs. Got a radiator & hoses going in this coming weekend. Than the oil leaks, then the timing belts & hopefully the last, new axles. Man! I am tired already. Thanks for the reply.
bigdawg74
May 28, 2013 08:48 PM
bigdawg74
Jul 30, 2011 06:50 PM
19Accord97
Jul 28, 2008 10:56 AM
MALSR
Jan 5, 2007 04:59 PM
deserthonda
Apr 16, 2006 04:22 AM
