Oil In The Spark Plugs?????
Old May 14, 2009 | 07:20 PM
ramman05's Avatar
Arrow Oil In The Spark Plugs?????
I have 1996 Accord LX 4 cyl, I was wonder what would be causing oil to be where the spark plug is. How do I go about fixing this
Thanks for any help.
Old May 14, 2009 | 10:29 PM
The search function is your best friend.
https://www.hondaaccordforum.com/for...ead.php?t=3088
I have never done the lower seals. Most likely the upper ones.
Old May 15, 2009 | 03:16 PM
jerrym's Avatar
Almost A Senior Member
I bought a kit from Autozone for about 20.00 or so. It included a valve cover gasket and upper spark plug seals.
Really pretty easy to install. I put the new plug seals in and just put a tiny bit of rtv on the cleaned up valve cover in a few selected spots to hold the gasket in place. Just don't tighten it down to much. I used a 1/4 inch drive socket/ext. and snugged it down, no problems now.
Old May 15, 2009 | 04:45 PM
deserthonda's Avatar
and if it turns out to be the lower seals,, just follow the write up .. it is an easy job ,,the most critical thing is to make sure that you reposition the rocker arms over the valves properly,, if you do not ,and tighten down the rocker arm you will bent valves
sirtwist2
Sep 24, 2012 01:36 AM
tiberius
Oct 17, 2006 11:51 PM
St3v3
May 14, 2006 04:05 AM
LinX
Feb 27, 2006 04:01 AM
hotrod20
Dec 4, 2005 11:04 PM
