OK im stumped
Old Apr 16, 2011 | 03:12 PM
cinobyte's Avatar
Default OK im stumped
92 accord
1.turn ignition to #2 and the engine light is on. start car it idles fine but gap the throttle any and it spits and sputters and about dies but does not.
2.Place paper clip in cel plug to read codes and the light does not blink. (im 99% sure I am jumping the correct plug)
3. pull out paper clip and the cel light goes out and you can start the car it runs and drives fine.
4. get back in car start engine and the cel light is back on and it is spitting and sputtering again.
5. repeat paper clip procedure and the light goes out car starts and runs fine.
any ideas?
Old Apr 16, 2011 | 03:51 PM
Suggest first resetting ECU by pulling BackUp (7.5A) fuse in underhood fuse box for 20 secs. Report back what happens next.
Check Engine Light should come on for 2-secs and go off when keyswitch is turned to On. This is a bulb-check.
Check FAQ's for code check procedure. Service Check Connector plug is a blue 2-wire plug and wires were Org/red and grn/wht in 90 Accord. It is usually plugged into a dummy female connector. Check autozone online manual wiring diagram for your wire color to be sure.
Old Apr 17, 2011 | 07:00 PM
cinobyte's Avatar
The problem was moisture in the electronics. i found the floor board to be wet and once i cleaned up all the water and let the car dry it starts with out all the stumbling and sputtering.
drummer1279
Oct 30, 2008 08:57 AM
toicy4ya
Aug 19, 2008 08:55 AM
gvox
May 9, 2007 12:33 PM
trinitron12
Apr 29, 2007 08:05 PM
Timmay
Jan 25, 2007 08:47 PM
