OPINION: OTC 7448A Fuel Injection Cleaner Tool
Old Nov 2, 2018 | 02:44 PM
lothian's Avatar
Default OPINION: OTC 7448A Fuel Injection Cleaner Tool
Anyone have experience with the OTC 7448A Fuel Injection Cleaner tool?
This thing is purpose-built to connect directly to the fuel rail (or just at the damper with an adapter) where it bypasses the fuel system and delivers fuel injector solvent under pressure, either their propriety brew, Inject-R-Kleen, or any similar product; eg: BG FIS, Chevron Techron, etc. (BG offers a similar device: the "VIA".).
The thing requires an air compressor to work. You hook-up shop air to the canister and dial-in the rail pressure for your vehicle. You then disable your fuel pump. fill the canister with solvent and hook up the delivery hose to your car's fuel rail via a quick-connect adapter. Open the valve, start the engine, and let it run until the canister is emptied (indicated by a stalled engine). Repeat with another can, or schedule another session twice a year or so. Cool huh?
I'm not a fan of gas-additive fuel injector cleaners, nor am I keen on the onerous chore of removing each injector for direct cleaning. At just over a measly hundred bucks for the 7448A (plus another twenty or so for the adapter), this seems like a reasonable regular maintenance tool for the home shop.
Anyone care to vouch for the OTC 7448A tool?
Old Nov 2, 2018 | 03:17 PM
rockhoundrob's Avatar
Never heard of this.
I just use B-12 or Seafoam.
Pour 1 can in the gas tank, once a year.
Old Nov 2, 2018 | 03:30 PM
The Toecutter's Avatar
Yup, same here B-12 or Techron once a year.
On my older vehicles, I might treat them to some premium once in a while.
Old Nov 2, 2018 | 05:38 PM
shipo's Avatar
Geez, mechanical snake oil.
Old Nov 2, 2018 | 07:08 PM
Even snake oil makes your car faster - because your wallet is lighter.
I've occasionally poured Techron in the tank, but it's probably been a couple years. It can only work to the extent that things are gummed up with crud. You'd have to buy a lot of fuel from shady places before you NEED that.
Old Nov 3, 2018 | 09:39 AM
lothian's Avatar
Question for those of you who've replied, and who use Seafoam, and/or other gas additive solvents:
Have you taken a gander inside your intake plenum (manifold) or scoped the inside of your cylinders, or peeked at the back of your intake valves? Granted, these aren't particularly pleasant tasks but neither are they particularly difficult. Nothing confirms efficacy like empirical observation, the opposite of "faith" of course.
Anywho...
BG offers the 'Vehicle Injection Apparatus', a tool that injects solvent into the intake plenum at the throttle body or the pvc port as well as through the fuel rail. The BG "VIA" seems the better tool investment than the OTC 7448A, Mityvac MV5567, et.al, Problem is, I can't source the thing..
Old Nov 3, 2018 | 10:43 AM
shipo's Avatar
Yes, I have peeked, what do those things have to do with wasting time on cleaning injectors? Answer, nothing.
Anywho...
Why bother screwing around cleaning the plenum? Unless there is something terribly wrong with your engine, the minor layer of varnish on the inside the plenum is irrelevant.
Old Nov 3, 2018 | 06:01 PM
Most times the inside of the plenum has a layer of oil mist and carbon deposits. Yes, I've looked. The oil mist is PCV by products, while the carbon deposits are from the EGR.
When I use B-12 or Techron, it's because the car has been parked a while, and the fuel has lost it's vitamins.
Old Nov 4, 2018 | 07:45 PM
I had my 95 accord injectors sent off to get cleaned and balanced after >200K miles. I never used additives in my gasoline. My injectors were almost 100% expected volume on all 4 injectors and all balanced.
I took off my intake on my 95 accord around the same time. There was a slight buildup inside, but nothing that would cause performance issues IMO.
d_10
Sep 19, 2007 07:11 PM
Draco
Oct 4, 2006 09:22 AM
thunder_x
Jul 29, 2006 09:11 PM
Jeff247
Feb 6, 2006 09:00 PM
nrangerfan
May 19, 2005 12:56 PM
