passanger windows problem
Old Jan 10, 2008 | 10:55 PM
tru3_k177's Avatar
Default passanger windows problem
hi guys, another day means another problem...
for some reason, my front passanger seat window took about 20 seconds to close up from a full open...
any idea why and ofcause any way to fix them?
thanx guys
Old Jan 11, 2008 | 12:13 AM
nafango2's Avatar
Default RE: passanger windows problem
try lubricating + cleaning the window track. I believe there is a link in the DIY section telling how to do that.
Old Jan 11, 2008 | 01:09 AM
patpatpat's Avatar
I had that situation last month. Here is what I did.
Lube the rails, now the rails is not the horizontal line with cloth feel, but the ones perpendicular to the ground.
Then I took the door panel off or have it out enough where you can clean out the cloth like material I mentioned earlier.
I used WD40 at first, but had better results after applying lubricant
Hope it makes sense
Old Jan 11, 2008 | 04:10 AM
tru3_k177's Avatar
@nafango2: i have searched through the DIY sections but I can't seem to find it anywhere hey...
Old Jan 11, 2008 | 01:18 PM
nafango2's Avatar
https://www.hondaaccordforum.com/m_77869/tm.htm
there ya go. it got moved.
MIA11
Apr 22, 2014 09:41 PM
sanchdaniel
Feb 5, 2011 06:59 PM
Calevra18
Sep 21, 2007 11:46 AM
RoKnAzn
May 16, 2007 01:46 PM
RoXeTTeMaN
Aug 5, 2006 03:22 PM
