Passenger window power failure
Old Apr 20, 2012 | 03:25 PM
msartell's Avatar
Default Passenger window power failure
I lost power to the three passenger windows in my '06 Accord LE. Driver's window works fine as well as sunroof. Have engaged/disengaged locking button for windows, checked fuses, but no success thus far. Welcome any suggestions.
Old Apr 20, 2012 | 05:39 PM
Tyler Joyce's Avatar
Sounds like a short to ground somewhere. Someone else could answer this because I dont know, but if those windows run in a series a short to ground sounds like a possiblity. I would start at one of the motors and see if your getting voltage to them. Finding electrical problems can be very hard if you dont know what your looking for.
Old Apr 20, 2012 | 08:26 PM
jroxz44's Avatar
Almost A Senior Member
Sometimes the window locking button breaks inside the switch. If the windows are locked not even the driver cant control them. I Had the same problem. Didnt know till i replaced the whole switch and took the old one apart. Junkyard 5$
Old Apr 21, 2012 | 09:42 AM
Any recent work done to the car?
Do you have a volt meter? If so you can test the inputs/outputs of the switch.
These two pic's are just part of the testing, all you need for this is something to "jump" the pins......two pieces of wire
Attached Thumbnails Passenger window power failure-7th-gen-power-window-pin-numbers.jpg   Passenger window power failure-7th-gen-power-window-wire-test.jpg
Old Apr 22, 2012 | 01:15 PM
msartell's Avatar
Thanks for your response. I'm beginning to believe that the problem is in the window locking switch. When I hit each respective window switch for the 3 passenger windows, I hear a click in the window switch on each individual door which leads me to believe that I'm getting power from the master switch to each door switch. Can you tell me how to either repair or disconnect the window locking switch? Since I don't use the window locking switch anyway, I'd rather just disconnect it if that's the quickest fix. Thanks again for your advice. msartell
Old Apr 22, 2012 | 02:47 PM
As far as I can tell from the wiring diagram, the wiring is internal for the window lock switch.
jroxz44 - Is the switch easy to take apart? Since you took the original switch apart, is this repairable? Or can you "repair" it, so the passenger windows will be unlocked all of the time?
Old May 24, 2012 | 11:19 AM
msartell's Avatar
As a follow-up to my original question about 3 of my passenger windows failing to work, you mentioned that the problem is probably in the window locking switch. Do you know if I can disconnect that switch since we don't use it anyway? If not, can just that switch be replaced or do I need to replace the entire master switch? Thanks for your help.
msartell
JayKranz
Apr 7, 2014 04:33 PM
Joel Barnes
Aug 3, 2013 03:54 PM
Brandon Saunders
Apr 17, 2013 06:44 PM
MyFirstAccord
Sep 7, 2012 11:04 AM
msartell
May 26, 2012 10:23 AM
