PCM/ECM replacement?
Old Aug 24, 2009 | 08:47 AM
rbrunner
Default PCM/ECM replacement?
Hello. I have a 2003 Honda Accord V6 with 194K on it. I've been taking it to a dealer because the check engine light come off/on. They weren't able to find any codes but thought it might be a O2 sensor or the PCM/ECM.
Now the car is running a bit rough at random times, the rpms drop. I also had the TCS light come on breifly.
So I'm thinking its the pcm/ecm. The cost at the dealers is a little scarey (around $800). Can I buy one on ebay and have the dealer put it in and program it?
Thanks,
rbrunner
Old Aug 24, 2009 | 07:41 PM
Flashing CEL can be intermittent, and not mean the ECU is dead. I would suggest having codes read immediately after seeing CEL on. Go to Autozone or elsewhere for a code check, or purchase a code reader.
Have spark plugs ever been replaced? If not they are overdue.
Old Aug 25, 2009 | 06:21 AM
rbrunner
Thanks I'll try it. The car was running way wierd yesterday acceleration problems then the TCS light coming on again. This morning made it to work but I'll go by the autozone before a dealer.
Old Aug 25, 2009 | 11:05 AM
mcnoople's Avatar
By TCS light on do you mean it is flashing? Flashing TCS on a throttle by wire car may mean the car thinks you are having wheel spin and is cutting throttle to control it. On your car there is no mechanical link between your foot and the throttle body.
Please describe "running rough"
Old Aug 25, 2009 | 02:12 PM
rbrunner
First running rough. The car's rpms will drop from 2200 to 1900 then back up. So the ride is rough not the engine itself.
The odd thing is that when the TCS light is on I cannot disengage it the button remains "on".
My wife thinks that I have a mouse that's eaten/chewed the wires somewhere in the car and that's the problem.. There is evidence of the little buggers but I could not find any obvious damage to any visible wiring.
Old Sep 17, 2012 | 01:34 PM
jiji's Avatar
Hey guys, the resolution to the code p0695 pcm ecm is the "tensioner" Just replace that and your car is good to go. I have had the same problem honda accord 2003 121000miles. The dealer could not resolve it; they kept talking of alternator, battery ground wire...but that never works. The trusth is that they never check the tensioner and that has been the main problem with those models. Replace it ($62) and tell me what your result is.
Jiji
Old Sep 17, 2012 | 01:41 PM
Jiji
Not necessarily, what causes a problem in one car does not always result in the same trouble code/problem for another car.
Old Sep 17, 2012 | 03:09 PM
Silver6gen's Avatar
every thing I've heard points to a rodent that has made a meal out of the electrical system...
The other item could be a wheel speed sensor... or possibly the ecu.... but ecu's rarely fail
Old Jul 3, 2017 | 10:31 AM
protosouls's Avatar
Default PCM voltage
Hello, I am experiencing the same issue with my 2004 Accord V6.
Did you ever figure out the problem?
I have jumpered the hi/low switch and it is broken. But after jumpering it I still have to jumper the relay for the clutch on the compressor. Only after jumpering both together, will the AC run.
The diagnostics I ran points to the PCM not sending the OK signal to the relay. I have made sure the relay works by switching it with a known working one out of another car.
Thanks for any help!
ciscorbin
Jul 6, 2017 01:25 PM
R.A.D.
May 2, 2014 11:39 PM
ssuh
Mar 27, 2012 08:10 AM
AccordMeister
May 6, 2009 06:57 AM
blazinfnestyle
Mar 19, 2007 06:02 PM
