Pin hole leak in fuel feed line @ pump
Old Mar 19, 2013 | 12:39 AM
BillHinek's Avatar
Default Pin hole leak in fuel feed line @ pump
Is there a repair coupling available or does the entire line have to be replaced.
This is a 2004 Honda Accord LX 4 cyl.
Pin hole caused by (varmit) chewed small hole in line about 4" from fuel pump.
Can access through fuel pump cover in trunk.
How long is the line? (it is hard plastic w/40 psi pressure, .4 " O.D. per Haynes manual)
Does it run continuous through the length of the car?
Have not been able to find a shop manual (would have to be Honda Shop Manual) that shows the length of the line.
Any real world info would be appreciated.
Bill
Old Mar 19, 2013 | 12:57 AM
Are you referring to part #28 in this image?
Attached Thumbnails Pin hole leak in fuel feed line @ pump-fuel-tank-1-465395.jpg
Old Mar 19, 2013 | 01:03 AM
BillHinek's Avatar
Yes, it is no. 28.
the parts breakdown answers my question,
It appears I will have to replace the full line and purchase the quick connect fitting retainers
in replaceing the line.
Thanks for the excellent parts display.
Bil
eduard
May 9, 2013 12:11 AM
PinkFloridaFlamingos
Nov 27, 2011 06:02 AM
kissbally78
Jan 18, 2009 07:14 PM
hondamecha
Jul 10, 2008 12:36 PM
ncsgoofy
Dec 4, 2006 01:04 AM
