Poppin plug wires
Old Mar 19, 2010 | 10:19 PM
myisu's Avatar
Default Poppin plug wires
I have a 99 honda accord that I've recently changed the plugs and wires on. On the way home frome work today, the wire of the #4 cyl popped off. Though not nearly that often, this has happened more than once in the last two weeks and prior to that it happened in '06.
Old Mar 20, 2010 | 01:03 PM
HondaAccordEX94's Avatar
Almost A Senior Member
Same problem. I pulled plug #2 off of the distributor, and now it doesn't stay on. Falls off all of the time.
Old Mar 21, 2010 | 09:01 AM
Myisu, which end falls off? Sparkplug end might be from a loose plug (compression pressure)?
Distributor end maybe bent or damaged the metal tab thing inside the wire. Use a needlenose pliers to make it tighter.
This isn't really a big "procedure" so I'll move this to Gen.Tech.
wannakeepmy94Accord
Mar 14, 2012 08:06 PM
Calevra18
Sep 16, 2007 10:45 PM
jrcastro
Jun 10, 2006 05:32 AM
deserthonda
May 29, 2006 03:28 PM
deserthonda
May 12, 2006 03:14 AM
