Sponsored by:
Sponsored by:
Poppin plug wires
Old 03-19-2010, 10:19 PM
myisu's Avatar
Default Poppin plug wires
I have a 99 honda accord that I've recently changed the plugs and wires on. On the way home frome work today, the wire of the #4 cyl popped off. Though not nearly that often, this has happened more than once in the last two weeks and prior to that it happened in '06.
Old 03-20-2010, 01:03 PM
HondaAccordEX94's Avatar
Almost A Senior Member
Same problem. I pulled plug #2 off of the distributor, and now it doesn't stay on. Falls off all of the time.
Old 03-21-2010, 09:01 AM
Myisu, which end falls off? Sparkplug end might be from a loose plug (compression pressure)?
Distributor end maybe bent or damaged the metal tab thing inside the wire. Use a needlenose pliers to make it tighter.
This isn't really a big "procedure" so I'll move this to Gen.Tech.
wannakeepmy94Accord
03-14-2012 08:06 PM
Calevra18
09-16-2007 10:45 PM
jrcastro
06-10-2006 05:32 AM
deserthonda
05-29-2006 03:28 PM
deserthonda
05-12-2006 03:14 AM
Quick Reply: Poppin plug wires
