Is it possible...? (Timing Belt Question)
Old Apr 19, 2014 | 03:52 AM
R.A.D.'s Avatar
Default Is it possible...? (Timing Belt Question)
Just purchased a 2003 EX-L 3.0L V6 with 150,000 miles. I have no way of finding out if the timing belt has been changed or not (I'm assuming and very much hoping it has...) Is there anything that would serve as evidence or indicate that it has been changed at some point?
Old Apr 19, 2014 | 04:39 AM
holmesnmanny's Avatar
you can pull the valve cover on the closest head and look at the belt .. you will look for cracks of any sort of wear
Old Apr 19, 2014 | 05:57 AM
Turtlehead's Avatar
There is a rubber plug one each of the upper t-belt covers which can be pulled out and you can look in at it, but you will see very little of it. Best way is to remove one of the upper covers and looks for cracking paying particular attention to the point where each tooth meets the flat portion of the belt as that is where the cracks will develop first.
Old Apr 19, 2014 | 06:50 AM
MysticBlueEX's Avatar
Almost A Senior Member
Check the car fax and see if any service was done at a Honda dealer, call them with the VIN and ask them if they have a record of the TB service.
I called around to local Honda dealers and found the one that performed most of the services on my car. The service writer was able to chat for a few minutes about what services were done already.
Old Apr 19, 2014 | 07:48 AM
Here's a good video but I did not find it very convincing:
You should have asked this question to seller. Doubtful you will get any help from a Honda service center.
In the end, a timing belt replacement is only way to be certain of engine protection.
Old Apr 19, 2014 | 08:15 AM
R.A.D.'s Avatar
Excellent info!
Thanks guys,
Steve
Old Apr 19, 2014 | 01:33 PM
homey's Avatar
Default When to replace
I finally got around to checking mine and here is what it looked like. These gates kits have really been working out for me. I got a tckwp244 today. Belts are so much easer and cheaper to change than heads and you still have to do the belts and waterpump when you pull the head if the timing belt breaks.
Old Apr 19, 2014 | 07:19 PM
wow thats awful .. a couple revolutions from busting
Old Apr 20, 2014 | 06:39 AM
homey's Avatar
Really lucky. I had the belt kit since christmas, just didnt get to it. Son removed power steering belt to get to the alternator belt. I asked him if he wanted to check the timing belt knowing the car was trashed if the belt broke. Once we pulled off the top cover and saw the top of the belt the car did not move again till replaced. It was a honda belt, the only reason it stayed together. Again I am really lucky on this one.
john_pyro
Aug 4, 2019 05:06 PM
newdaddy26
Jul 28, 2013 01:43 PM
Jay 3rd
Feb 17, 2008 10:54 PM
toddyfresh
Dec 2, 2007 06:05 PM
Tony1M
Apr 1, 2007 05:42 PM
