power locks and alarm 97 Accord
Old Oct 18, 2007 | 03:41 PM
HAFAccord97
Default power locks and alarm 97 Accord
I drive a 1997 Accord EX 4Dr.
It has an anti-theft alarm system which was installed at time of purchase by the Honda dealer. It appears that the alarm is malfunctioning. Once the engine is started after a few moments the power locks all get locked. I believe this is the feature of the anti theft alarm system (I could be wrong). About a year ago the rear power locks stopped locking and would keep making a whirring sound trying to lock. It would not respond to the remote key command to lock or unlock. So I had the power lock mechanism on both rear door replaced (I think its called the accuator or something like that). So now the lock responds to the remote key and it also locks when the engine is started. However, the locks keep making a clicking sound as if its trying to lock. I am told this is because the alarm is malfunctioning.
So my question is, is there a way to disable the alarm?
The alarm even though installed by the Honda dealer is an after-market product.
I would appreciate any help on this. Thanks.
Old Oct 18, 2007 | 03:54 PM
nafango2's Avatar
Default RE: power locks and alarm 97 Accord
most power remote entry / alarm systems have 2 power door lock settings. 1 ouputs a short burst of current to lock/unlock the door, and the other option outputs a couple of seconds. ( this is for other types like pneumatic locks and some other power door lock styles) read the alarm manual to see how to change it/find out what its set to. I could have gotten changed somehow.
Also try just unplugging your alarm system to see if the problem goes away.
If it still makes the sound when your using the lock/unlock buttons by the door handle (the non-keyless ones) it is VERY unlikely that its the alarm system.
Old Oct 19, 2007 | 05:40 AM
2POINTautO's Avatar
Drivers door actuators causing these same problems is very common. It is the master door lock input device.
If you use the key in the door lock to unlock the doors the old fashioned way, the drivers door actuator controls all the other actuators.
Old Oct 19, 2007 | 12:17 PM
falkore24's Avatar
Do the doors that are having the problem work properly when you use the door lock switch?
mpkeith
Mar 21, 2014 01:38 PM
Erik Faber
May 2, 2013 06:39 PM
losrico
Oct 18, 2012 05:26 PM
Opballer
Feb 9, 2012 11:54 PM
Antarctica
Oct 5, 2010 08:33 PM
