problemas con honda accord97
Old Jan 27, 2011 | 09:40 PM
wilkava's Avatar
Unhappy problemas con honda accord97
hola me gustaria me ayudaran tengo un honda accord 97 el problema que tengo es cuando el carro esta en parking o en neutral las revoluciones se suben y se bajan ya le cambie el tps la computadora limpie los inyectores y no he resuelto el problema ademas el scaner no me detecta ninguna falla ni sensor malo alguien me podria decir donde pudira estar esta falla cambie el tps y el sensor map pero no he resuelto el problema me da la impresion que puede ser un problema electrico pero no estoy seguro y ya estoy cansado de estar lidiando con este problema sin poder resolverlo hay ocasiones que el carro trabaja normal lo apago y cuando lo vuelvo a encender se presenta de nuevo el fallon su ayuda por favor si alguien sabe o ha tenido un problema con este en su honda
Old Jan 27, 2011 | 11:18 PM
Does any member speak the words above?
If so you can help him out..
Thanks
Old Jan 28, 2011 | 07:24 AM
[quote=google translate]
Hi I would like to help me I have a honda accord 97 the problem I have is when the car is in park or neutral the revs are up and down and I changed the tps the computer clean injectors and I have not solved the problem besides the scanner I do not detect any failure or bad sensor could someone tell me where this is all your fault pudira change the tps and map sensor but I have not solved the problem gives me the impression that may be an electrical problem but am not sure and I'm tired of being dealing with this problem without being able to solve it there are chances that the car works normal when you turn it off and back on again presents fallon please help if anyone knows or has had a problem with it in his sling[\quote]
First, I'm going to move this to General Tech where it belongs.
Wilkava, look in the DIY section for instructions about cleaning & tightening your FITV.
Then also look for instructions about setting the BASE idle and forcing the car to re-learn the idle.
Old Jan 28, 2011 | 04:58 PM
hondamanic's Avatar
chequea la iacv valve sacala y la limpias no mojes el solenoide eso te resolvera el problema ya que nueva es cara
JEB0007
Apr 29, 2011 11:04 AM
kellysa111
Jul 12, 2009 06:10 PM
bruffy
Nov 17, 2008 02:35 PM
spliffy
Jul 29, 2008 05:31 PM
ckebottle
Apr 18, 2007 11:41 PM
