To pull or not to pull engine for clutch/engine work. '88 LXi
Old Apr 4, 2015 | 06:00 AM
  #31
I wouldn't worry with it, I think it is the way the gear is "cut" that makes it a bit lounder than the others.
While out and doing all of this, it wouldn't hurt to change the fluid in it. In the 3rd gen's I've always used regular motor oil in the manual trans.
Last edited by poorman212; Apr 4, 2015 at 08:04 AM. Reason: I can't spell, nothing new :)
Old Apr 4, 2015 | 06:44 AM
  #32
shipo's Avatar
Originally Posted by vetski179
Flywheel resurface done, was able to get the bushing back in place.
Before I put trans back in, a question about it: For as long as I remember, the trans emitted a strange sound when in reverse. Like an enhanced gear whine. Above and beyond the normal gear whine. Wondering if this is common and not to worry, or should I open up the trans and investigate?
I've owned cars with manual transmissions from every decade since the 1960s, and from Asia, Europe, and the U.S., cars with 3-Speed units (one with a "Three on the Tree"), 4-Speed, 5-Speed, and 6-Speed, and every one of them would whine when in reverse. As poorman212 says, it is the cut of the reverse gear.
Old Apr 13, 2015 | 02:27 AM
  #33
vetski179's Avatar
Default Main shaft damage
After much thought I decided to pull apart the transaxle to check out the noise when in reverse. Regrettably, there is damage to the main shaft and corresponding gear on the counter. It seems the mainshaft is no longer available from Honda. Plus, the asking price was in the $250 range. Frankly, even if it were available, I wouldn't spend that much, as gears 1-5 work fine with no noise. But, if I could get it cheaper, I might. Any ideas?
Attached Thumbnails To pull or not to pull engine for clutch/engine work. '88 LXi-dsc01792.jpg   To pull or not to pull engine for clutch/engine work. '88 LXi-dsc01793.jpg   To pull or not to pull engine for clutch/engine work. '88 LXi-dsc01791.jpg
D_Thor
Jan 2, 2014 10:25 PM
ozofjakes
Jan 4, 2013 09:09 PM
loadder
Jan 31, 2009 11:04 AM
mck52689
Jul 17, 2007 03:40 PM
tamb
Jul 21, 2006 01:05 AM
