Pump noise on cold startup
Old Mar 26, 2013 | 08:23 PM
Hangfire79's Avatar
Default Pump noise on cold startup
2009 Accord V6, 33k miles. On a cold startup such as first thing in the morning or after my shift at work, I hear a somewhat high pitched noise which sounds like a pump cycling. It's been cold here and it's done it the last 2 days. Thanks for any help.
Old Mar 26, 2013 | 08:24 PM
Hangfire79's Avatar
It only does it for about 2 seconds.
Old Mar 26, 2013 | 09:09 PM
Old Mar 26, 2013 | 09:47 PM
Hangfire79's Avatar
Yup, almost identical.
Old Mar 29, 2013 | 07:46 PM
Hangfire79's Avatar
So it's the alternator?
Old Mar 29, 2013 | 08:02 PM
Alternator....I don't think so.
It is sounding more like the vtc solenoid to me. Cold start....hours of sitting and then "errr" on start. I've seen this on the 4cyl before. Need to check on the 6 cyls?
Old Mar 30, 2013 | 05:51 PM
Hangfire79's Avatar
What do you think it could be? I have no clue.
Old Mar 31, 2013 | 01:09 AM
It is a known problem with the vtc solenoid. Just search the web about this topic, because it has been covered.
Old Mar 31, 2013 | 08:55 AM
Hangfire79's Avatar
Thanks for the the replies
Old Mar 31, 2013 | 10:58 AM
I don't believe the V6 had VTC (Variable Valve Timing Control); so, the Honda technical service bulletin (TSB) for the 4 cylinder is not applicable to the V6.
cryptonate
Nov 12, 2009 05:09 AM
ufosearch
Mar 2, 2009 10:59 AM
gaugeman
Mar 10, 2008 01:30 PM
farango
Feb 11, 2008 08:12 PM
trukid21
Mar 6, 2007 10:08 PM
