Squealing Noise on Startup
Old Mar 10, 2008 | 10:42 AM
gaugeman's Avatar
Default Squealing Noise on Startup
Guys
My son's '92 DX make a "belt" likeSquealing noise on start up and then it abates. He now claims to here it every now and then.
I've tightened both belts and that seems to help for awhile, but the noise returns after a few days/weeks. I now think that the belts are too tight, but it still squeals as much or more than ever. I don't think the alt. or AC, or PS bearings are bad.
I'm begining to suspect the Crank pulley. Has any one been through this scenario before? Is it possible the rubber in the pulley is or hasgiven up?
Old Mar 10, 2008 | 10:56 AM
brayner's Avatar
Default RE: Squealing Noise on Startup
are the belts in good shape? glazed over? Mine liked the belts adjusted very tight to not squeek
Old Mar 10, 2008 | 11:01 AM
It's possible for the rubber in the crank pulley to be slipping. You can check by using a timing light to measure your spark timing. If the pulley is slipping, the spark timing will APPEAR to move back over the course of days or weeks.
But...
It's also possible that the belts are hard & slippery from age. This might be more likely than the pulley. Try some belt dressing. That's only temporary, but it can demonstrate that it's the belt rather than the pulley.
Old Mar 10, 2008 | 11:30 AM
gaugeman's Avatar
I forgot to mention that the belts are new.
Old Mar 10, 2008 | 01:30 PM
Well, I guess that leaves the pulley or the bearings.
Take off all the belts, see whether you can spin the pulley against it's hub.
Use something like a sharpie marker or a scribe to put a mark across the rubber,from thehubout to the pulley. Over time, that mark will move around. Or not...
purvisj2
May 22, 2020 01:20 PM
heathb
Nov 9, 2010 05:44 AM
Rupert305
Apr 4, 2010 04:40 PM
jenny
Oct 17, 2008 04:23 PM
will93
Feb 13, 2008 02:33 PM
