Question About AC
I am trying to get the AC working in my 2000 Accord. I have a bypass pulley in place of my compressor.
Once I install the new compressor, do I need to just add freon? Or will I need to take it to a shop for them to do something? Thanks
if the system has been open to the atmosphere, you are HIGHLY recommended to change out the receiver/drier and have the system flushed from the condensor to the evaporator, and a new expansion valve wouldn't hurt either. And yes a professional should pull vacuum on the system, make sure it holds, check pressures when it's filled and running and add dye to check for future leaks...why was the original compressor removed?
A siezed compressor can leave debris in the condensor and evaporator that may return to damage a new compressor. Suggest taking the time/expense to replace these components. Cleaning is not possible due to parallel flow paths preventing effective flushing.
Following are key steps to recharge:
1) Install lubricating oil in new compressor and new receiver/drier
2) Pull full vacuum and check that vacuum holds for at least 15 mins. If not leak must be found and repaired.
3) Once vacuum holds, continously vacuum for at least 1/2 hr to remove moisture from system.
4) Charge w/ correct weight of refrigerant, usually about 24 ozs or approx. 2 cans of R134a. Avoid use of sealants or cooling enhancers.
Stopormymomwillshoot
Aug 29, 2010 06:18 PM
greg05
Aug 17, 2009 08:22 AM
