Question about halfshaft?
Old Feb 27, 2007 | 06:21 PM
RSM93HONDA's Avatar
Default Question about halfshaft?
On the drivers side halfshaft there was what looked like a rubber bump stop. Is this a bump stop or a weight? My new halfshaft does not have one and im getting a vibration around 3000 RPM. Any suggestions would be appreciated. Thanks.
Old Feb 27, 2007 | 08:13 PM
hondadude's Avatar
Default RE: Question about halfshaft?
Yes that rubber part on the old shaft was on there to help 'balance' the long shaft.
The problem is you have to remove the shaft and take apart the inner joint, to slide it back on the shaft and then reclamp it in place.
I would be more inclined to believe it would cause a vibration at higher speeds as opposed to RPM though?
OEM parts only hurt once.
Old Feb 28, 2007 | 01:39 AM
RSM93HONDA's Avatar
Is there anything else i could use to substitute for the rubber piece? I no longer have the old half shaft. Thanks.
Old Mar 1, 2007 | 05:22 AM
RSM93HONDA's Avatar
Anyone have a thought on this? Thanks.
Old Mar 1, 2007 | 11:24 AM
deserthonda's Avatar
I have had to replace quite a few axles with non honda ,, that did not have that part ( DAMPER WEIGHT ) installed and never have had a shaking problem, As a matter of facts in some occasion the rubber piece has broken off ,and thedamper slides off on the axle creating a noise. i had to totally cut them off and remove them .. again,, no shaking afterward ..
if shaking started after the axle replacement you might want to warranty the shaft and try a different one ,
,OR get 1 ( damper weight ) from the dealer and install it,it costs about 25-30 dollars
greg05
Aug 17, 2009 08:22 AM
uglyblackhat
Jan 10, 2008 05:38 PM
toddaccord
Nov 6, 2007 09:16 AM
Jeffmo
Mar 7, 2007 10:09 PM
fendigyal
Oct 7, 2006 09:46 AM
