Question about Struts, new tires, alignment...
Old Jan 9, 2013 | 07:17 PM
aloha_bruddah's Avatar
Default Question about Struts, new tires, alignment...
93 accord ex coupe..............
i have new struts for the front and am getting 4 new tires....I am going to do the struts this weekend and then go put on the tires, I know it's going to need to be aligned, my question..............
if i do the rear struts next month, do i have to do another alignment???
thanks for your answers!!!
Old Jan 9, 2013 | 11:23 PM
basket_case's Avatar
Unless I'm missing something or unless the previous alignment was done with the struts bent or springs really sagging, I wouldn't think the alignment would be affected by the new struts. Upper and lower ball joints, radius rod bushings, control arm bushings and tie rod ends would have a much greater impact on alignment. I think struts would have to be in really bad shape to influence alignment.
Old Jan 9, 2013 | 11:51 PM
i'm just aking, if i do all this work, get it aligned, and then do the rear struts, will i have to do a second alignment........I know i should just do it all at the same time, but due to budget constraints........
Old Jan 10, 2013 | 12:54 AM
My alignment buddie here in Ohio said that you will need to realign the whole car again after you do the others..
Old Jan 10, 2013 | 10:39 AM
I think the front struts on a 93 do not contribute to the alignment. If the control-arm balljoints are separated at their tapered studs (rather than other bolts), then the alignment shouldn't change.
Another suggestion is to wait a couple hundred miles for all the new parts to shake & settle. THEN get an alignment.
Old Jan 10, 2013 | 12:27 PM
Talking Hi Jim :)
I think you 2nd suggestion is the best one..I concur after looking it up also..
Old Jan 10, 2013 | 07:23 PM
hondafreak91c's Avatar
I agree with what Jim said......do everything, allow it to settle, then get an alignment.
kakarotoni
Sep 14, 2010 07:12 PM
falkore24
Oct 3, 2007 06:18 PM
ckebottle
Jun 7, 2007 09:02 AM
maro
Mar 10, 2007 12:15 AM
BostonPuppyDawg
Oct 3, 2006 01:24 AM
