Rack Power Steering Leak
1998 Accord LX 4 Cyl automatic - 185,000 miles
There is a small leak in a hose near the bottom of the radiator. It is part of the power steering line. I plan to replace the 3 rubber hoses and the power steering reservoir. When I remove these hoses, can I get an air hose and blow out the power steering fluid that goes to the pinion rack? I just want to replace the fluid while I am at it. If not, is is OK to just add new fluid and then it is about 25% old and 75% new?
It is possible but difficult to repair a leak from end of the rack (leaking from end seal into dust boot). See following video of repair of Toyota Tundra. It will be similar for Accord, but access may be more difficult. You would need to assess whether a DIY is possible.
darkgreen18290
Jun 25, 2013 07:51 AM
