radiator fan noise
Old Nov 3, 2010 | 04:41 PM
Palofbills's Avatar
Default radiator fan noise
Year and trim accord : 1994 lx
Your request for a DIY write up : the radiator fan ( left / when facing windshield) ; makes a rattling / shaking noise ; upon visual inspection ; it is wobbly ; Turning well ;
Any additional notes that need to be added : heats & cools well ;
Thanks
Old Nov 3, 2010 | 07:23 PM
There is a nut that retains the fan blade. They can sometimes come loose and cause blade to wobble. Sooner/later the motor shaft will strip the fan blade slot and blade won't turn correctly.
Another explanation is fan motor bushings are worn/failing (less likely).
Best bet is to pull the fan assembly and see if blade retaining nut can be retightened to shaft and correctly hold the blade. If fan blade opening is wallowed out, you will need to replace either the fan blade or entire fan assy. Check ebay, rockauto for parts options. Not expensive.
You can temporarily operate w/o one fan until you get a replacement. Don't use AC except at highway speeds in this condition.
BigRoach
Jun 3, 2013 01:54 PM
Novaknowledgenow
May 30, 2013 08:58 PM
hmr
Mar 28, 2012 10:49 PM
daddy
Feb 6, 2006 02:52 AM
meazz1
Jan 21, 2006 02:43 PM
