Raditor Fan Problem
Old Oct 2, 2009 | 06:37 PM
or12101989
Default Raditor Fan Problem
I got a 95 accord lx and this radiator fan problem recently starting to happen. The fan will not start at all when Im driving it at all this obviously mean that it start to heat up when Im idling. But the wierd part is that the fan turns on when I start the car. Any suggestions?
Old Oct 5, 2009 | 08:45 AM
There's 2 fan switches. The on in the thermostat housing (#16 in the picture) is responsible for the fan while the engine's running. Unplug it, & use a paperclip to short between the 2 wires. Key on, that should make both fans run. Let us know if it does.
The other fan switch is #18, in the nozzle for the UPPER radiator hose. That one is responsible for the fan running after you turn off the engine.
In the end of the head, #15 (one-wire) is the sender for the dashboard temperature gauge. Next to that, #19 (2-wires) is the temperature sensor for the ECU.
bigwater
Dec 14, 2011 04:22 PM
CDJDM07
Aug 24, 2011 09:51 AM
ramachan9
Jul 11, 2009 11:57 PM
Equalizer
Feb 20, 2007 08:57 PM
daddy
Feb 6, 2006 02:52 AM
