RE: Any Help on Radiator Repair?
Old Mar 26, 2007 | 12:10 AM
brave_mhy's Avatar
Default RE: Any Help on Radiator Repair?
Hi, Guys! I found some coolant leaking out from the connection area of the core fins and the top plastic pipe on which the radiator cap sits. I touched the lower lip of the connection edge, and there was trace of coolant along quite a length (about a foot) spreading from the radiator cap point. I have read the thread in DIY section about changing the whole radiator, and the thing I am concerned about in changing the radiator is that it seems that I will be stuck half way there when disconnecting the hose to the auto tranny(I failed once when i was flushing the cooling system andtried to drain the liquid more completely)
Anyone has any clue about if there is a gasket or sealing material between the connection of the core fins body and the pipe (It looks from outside there are quite a few little teeth from the core fins body that were bent to hold the pipe in place) so that I can replace, or is there any quick adhesive that can be applied to seal the leaking cause I suspect the little teeth will be torn apart from the body when I open them. Anyway Iam trying to keepmy work minimizedsince it is a 95' 4d LX, auto with 100k on it, all the parts are so old, and I am worried if all the rusty parts will go back to their original place after I remove them from the place.
Appreciate any help in advance!
Old Mar 26, 2007 | 12:16 AM
deserthonda's Avatar
being that the car is that old i would install a new non-honda radiator and a new cap ,, cost is around 100-120 dollars .. there is an (How to replace radiator )on our DIY section
Old Mar 26, 2007 | 02:32 AM
chibiko's Avatar
you can use some "J-B weld" for repairing leaking radiator. I used a kind of similar stuff, which don't need to be mixed, to repair my radiator and it has been working for a couple of months by far without any problem. I forgot the name of it. I bought it from walmart, black, some kind name of "cold weld" or "cold iron".
Old Apr 17, 2007 | 10:53 PM
brave_mhy's Avatar
Thanks a lot masters!
Old Apr 17, 2007 | 10:55 PM
brave_mhy's Avatar
Hi, deserthonda, where is our '007'?
RTexasF's Avatar
Super Member
If you plan to keep it thenreplace it, don't try to repair it.
Old Apr 17, 2007 | 10:59 PM
brave_mhy's Avatar
Thanks for input, RTexasF!
Old Apr 17, 2007 | 11:03 PM
RTexasF's Avatar
Super Member
The plastic/aluminum radiators are generally a throw away item.
Old Apr 18, 2007 | 01:12 AM
ORIGINAL: brave_mhy
he had to go an a mission ,, His buddy is sitting in for him .
ORIGINAL: brave_mhy
BigRoach
Jun 3, 2013 01:54 PM
Novaknowledgenow
May 30, 2013 08:58 PM
hmr
Mar 28, 2012 10:49 PM
rtmobile96
Sep 14, 2007 05:07 PM
thunder_x
Dec 11, 2006 12:16 AM
