Rear Motor Mount
Old Sep 25, 2014 | 11:56 AM
Elguyo's Avatar
Default Rear Motor Mount
How do I determine which rear motor mount to buy (with or without solenoid) for a 92 accord dx auto. I could not determine by looking in the engine compartment. Do most of these cars have the Solenoid type? Car was manufactured in Japan.
Thanks
Old Sep 25, 2014 | 12:16 PM
Usually the "auto trans" cars have the vac controlled rear mount.......has the solenoid.
You can get under the car - use safety. if there is a vac line going to the mount, that will confirm it came with the solenoid.
EDIT: I didn't think they did that until the 5th gens but I'm going on memory which is bad.
Old Sep 25, 2014 | 12:48 PM
You should be able to see the engine mount control solenoid valve and the vacuum lines running to the mount from the top of the vehicle. Attached is a photo of the location of the solenoid valve.
Attached Thumbnails Rear Motor Mount-engine-mount-control-solenoid-valve.jpg
Old Sep 25, 2014 | 12:52 PM
See my post #5 in this thread for some more info.
https://www.hondaaccordforum.com/for...35/#post287625
baer77
Feb 27, 2009 03:47 PM
Naked TREE 2X4
Sep 1, 2007 07:38 AM
bedwards97
Mar 14, 2007 03:51 PM
trvlnut
Oct 30, 2006 02:16 AM
Markus26
May 17, 2006 09:28 PM
