removing a few bolts or thing off suspension
Old Nov 4, 2012 | 09:51 PM
lmrj0030's Avatar
Default removing a few bolts or thing off suspension
1998 v6 2 door
I can't manage to slip out the thing (what are they called) out
and the last 2 images is the same. The bolt seems to be stuck on the rubber and when i twist it, it will twist. however it will go back to it's original position.
How should i tackle this?
I'm trying to do a 5 lug conversion and i heard that the coupe v6 will fit in the sedan. This is true right?
http://imageshack.us/a/img209/904/img1882g.jpg
http://imageshack.us/a/img442/4071/img1881hw.jpg
http://imageshack.us/a/img17/5707/img1880hz.jpg
http://imageshack.us/a/img341/7678/img1879su.jpg
Old Nov 5, 2012 | 06:44 PM
A bigger hammer and some spray lube.
I assuming rear here.
Work the arm at the hub in and out while using the lube.
Attached Thumbnails removing a few bolts or thing off suspension-6th-gen-rear-knuckle.jpg
Old Nov 5, 2012 | 09:22 PM
Hamster108's Avatar
air hammer
erniep24
Nov 21, 2014 11:24 PM
anangphatak
Oct 29, 2012 06:24 PM
pbplayer257
Apr 15, 2010 07:21 PM
zann121
Jun 19, 2009 12:59 PM
egonzal24
Dec 8, 2007 12:08 PM
