REMOVING wheel bearings?
Old Oct 19, 2006 | 10:00 PM
lightshow's Avatar
Default RE: REMOVING wheel bearings?
check around a little on the site and check out what desert has done on here. if we were playing san andreas gta right now he would be walking around with 2 guns. its your rotors.......no question completely stop thinking about the wheel bearings because its your rotors. they cannot be check visually for runout.....it must be put on a lathe. just take the rotors off and have them turned and put on some new pads. your problem will be solved. again this is a rotor problem
Old Oct 19, 2006 | 10:49 PM
ORIGINAL: BigMike
Is there a way, visually, i can tell if my rotors are warped. Can it be the brakes pads too....or not likely?
Thing is, what most people call 'warped' rotors is usually a misnomer. They can be geometrically perfectly true. So for example you measure with a dial indicator & they're OK.
Material from the pads gets deposited on the braking surface of the rotor. If you like to stamp the brakes & make them good & hot, one BAD thing is when you stop at a red light. The surface of the rotor that's clamped by the pads for 90 seconds behaves very different than the remaining surface of the rotor. Pad material then gets deposited unevenly. It's not warped, but it's friction properties become very non-uniform around the rotor. Get it??
Sometimes this non-unform imprinting of pad material onto the rotor is visible, but not always.
Old Oct 20, 2006 | 11:39 PM
Alekat's Avatar
BIG MIKE:
When you remove the calipers - look at the thickness of the inboard pad, (piston side) and the outboard pad and compare them. If one happens to be less than the other then you could have a piston or a slider not releasing to a relaxed position. This is usually not a concern unless the vehicle is pulling to one side at road idle, (level road and tire pressure checked of course). Rare but, something to check when viewing the pads.
Old Oct 21, 2006 | 12:01 AM
YeuEmMaiMai's Avatar
if you think your bearings are bad you can turn your wheels while driving and the sound will change pitch....
Old Oct 21, 2006 | 04:04 AM
Slusher's Avatar
Big Mike, I agree with these guys 100%. I had a very similiar problem to yours and I thought well, brakes are pretty worn and need to be replaced within the next few miles so go ahead and do it; and the problem was fixed for me. Some honda dealerships do a brake inspection for like $20 and most honda dealerships are equipped to turn rotors while they are on the car.
Old Oct 21, 2006 | 04:11 AM
deserthonda's Avatar
ORIGINAL: Alekat
Unless you installed the rotor(s) on a lathe - it is difficult if not impossible to tell.
Not true......you can chk rotors with a micrometr ( parallellisim )and a dial indicator ( runout )
Old Oct 21, 2006 | 10:57 PM
  #17
Alekat's Avatar
Sure can but, what I read led me to believe: The content of the post indicated the posters experience was not advanced to the degree that would provide the knowledge to use those kinds of tools.
Old Oct 21, 2006 | 11:27 PM
  #18
Chiovnidca's Avatar
ORIGINAL: Alekat
It's not that tough to measure a rotor for runout and parralelism. Haveing the tools a different matter.
Old Oct 21, 2006 | 11:31 PM
  #19
Chiovnidca's Avatar
ORIGINAL: JimBlake
I've still haven't seen that on a honda with stock type pads and rotors. I think it's a race car thing. Rust buildup does as you describe though.
cclingma
Jan 10, 2008 05:49 PM
oma93
Dec 10, 2007 09:21 PM
advokat
Oct 15, 2007 10:54 PM
dexter1
May 30, 2007 08:02 PM
panamared
Apr 6, 2007 02:08 PM
