Replace Power Steering Pump
Old Jun 29, 2015 | 12:36 PM
devinzmax's Avatar
Default Replace Power Steering Pump
Hi All,
I have a 2006 Accord V6, and the power steering pump needs to be replaced. Does anyone have a DIY on this?
My main concern is, do I have to bleed the system when the new power steering pump is installed?
Also, I plan on purchasing the parts from one of these online Honda dealers. Is that a good idea?
Thank you all!
Old Jun 29, 2015 | 02:28 PM
I moved post to appropriate forum for responses.
Bleeding is not necessary as pump circulation will circulate air out of system. Turn steering wheel to stops while idling to get air out of PS rack.
Check youtube for videos on Honda Acura V6 PS pump replacements. All are similar. This is a very straightforward operation. PS fluid drainage can cause a mess, so rags/paper to catch spillage is essential.
Removing serpentine belt can be tricky. I used two combination wrenches linked together to gain enough leverage. You may be able to get a breaker bar and socket in place as another option. Get a diagram of serpentine belt routing to insure correct replacement. Leave belt in place to extent possible.
Old Jun 29, 2015 | 02:37 PM
devinzmax's Avatar
Thank you! This helps!
Old Jul 1, 2015 | 12:09 PM
Turtlehead's Avatar
Recommend you make sure it is the pump? There are two COMMON things that can cause the pump fail issue other then the pump, one is the o-ring on the pressure line the the other is the high pressure line if the car has had a hard side impact on a curb etc. regardless always check the lines for leaks. If one is detected then throughly clean the lines and recheck for the leak. Lastly be sure that there is no fluid behind the inner tie rod boots which would indicate a seal failure on the rack. This is all assuming you are not replacing the pump due to a bearing failure... Good luck.
divinations
May 31, 2013 07:52 PM
across55
Sep 17, 2009 12:02 PM
Tony1M
Sep 4, 2006 08:52 PM
WS6M21
Nov 9, 2005 01:50 AM
