Replaced fuel lines and now car won’t start. Help!
Old Feb 24, 2022 | 09:32 PM
The diagram in the shop manual is pretty confusing on how the fuel hoses are routed. Did you also remove the banjo bolt to verify no fuel was coming out of the feed line?
Is it easy to switch the two lines with how you repaired them?
Old Feb 25, 2022 | 04:43 AM
Trevor C.'s Avatar
Hi PAhonda,
Will there be a major issue if I swap the lines and try to start the car? I think I’m at that point.
Thanks,
Trevor
Old Feb 25, 2022 | 03:08 PM
I don't think you'll have a major issue if you swap the lines.
Old Feb 25, 2022 | 06:14 PM
Trevor C.'s Avatar
Hi PAonda,
No, I didn’t remove the other line. I guess I can.
however, if you don’t think that there may be an issue with swapping the lines to check, I thought I’d start there.
thanks again for all of your help!
Trevor
Old Feb 26, 2022 | 05:31 PM
Trevor C.'s Avatar
I did the fuel line switch and it started right up 🙂.
feel like a bonehead. Don’t know how in the world that even happened, as I removed the lines one at a time.
Thank you again for the help! I GREATLY appreciate it.
Trevor
Old Feb 27, 2022 | 08:39 AM
No worries. I've made many bonehead mistakes during DIY work. I'm sure I'll have some more in the future.
Thanks for posting the results. Hopefully the swap was simple.
live2snowboard
May 4, 2018 09:37 AM
djklacka
Oct 4, 2011 08:41 PM
double b from wv
Sep 25, 2011 05:11 PM
ANDYS87
Sep 12, 2011 05:33 AM
Adler
Apr 14, 2011 04:51 PM
