replacing an O2 sensor
Old Dec 2, 2008 | 09:03 AM
bmeinert
Default replacing an O2 sensor
OK, so I went down to my local auto parts store and found out I have a bad O2 sensor. I would like to do the install myself and would appreciate any helpful tips for the job. I am driving an 03 accord EX with a 2.4 cyl.
I am new to this forum, soplease let me know if there is any other important info I should be providing.
Thanks
Old Dec 2, 2008 | 09:07 AM
finch13's Avatar
Default RE: replacing an O2 sensor
There are 2 O2 sensors.... do you know which one it is?
Old Dec 2, 2008 | 09:11 AM
bmeinert
I was under the impression that there was only one to replace. The guy made it sound like it was close to cat. I am picking up the part later today, I guess I can clarify at that time.
Old Dec 2, 2008 | 10:10 AM
bmeinert
Here is some more info on the problem. Auto Zone indicated a P0141 code. A malfunction exists in the heater circuit for oxygen sensor 2 in bank 1. Sounds like it is on or after the cat. Any special tools needed and will the code need to be reset? Or, do I simply disconnect the battery.
Thanks
Old Dec 2, 2008 | 12:56 PM
finch13's Avatar
Check out this thread:
https://www.hondaaccordforum.com/m_142812/tm.htm
Old Dec 2, 2008 | 02:39 PM
bmeinert
Thanks for all the insight on my issue. I think I have a handle on how to proceed from here. Once this is resolved I might even send a sarcastic thank you to my local dealer.
Old Dec 2, 2008 | 02:43 PM
finch13's Avatar
Good idea! Keep us posted on how it goes and if you need any more help!
Old Dec 3, 2008 | 07:40 PM
I read that other thread, & Im pretty sure that for 2003 the plug tothe wiring harnessis actually inside the car, under the carpeting beneath the front seat.
Old Dec 4, 2008 | 08:55 AM
jcocker03's Avatar
you will also need a special socket to remove the sensor
Old Dec 4, 2008 | 09:10 AM
finch13's Avatar
ORIGINAL: jcocker03
Not if you use a wrench!
pondrun
Nov 8, 2021 09:40 AM
jaydev
Mar 26, 2012 09:18 PM
mkeyrouse
Dec 28, 2011 12:29 AM
nrobinsontcnj
Feb 15, 2010 02:29 PM
kris_loehr
Dec 19, 2008 07:20 PM
