Replacing Tie Rod Dust Seal Boots
Old Jan 2, 2014 | 10:49 AM
  #41
faran's Avatar
Almost A Senior Member
Thanks so much for your help, you mean crow wrench?
Is there any direction for 'Stopper washer(Big one)' or it can go both ways?
Old Jan 2, 2014 | 12:40 PM
  #42
I think the tool is a special purpose tool rather than a large crowfoot, but could be mistaken.
If washer is flat it should not matter which way it's installed.
Old Jan 2, 2014 | 03:54 PM
  #43
It looks like that "stopper washer" has serrations on one side. Those serrations should go in against the rack like they are shown in your post#36 picture.
Old Jan 4, 2014 | 07:47 AM
  #44
faran's Avatar
As always, thanks so much guys.
I am going to try and fix it today, will post back any issues/outcome
Old Jan 4, 2014 | 07:49 AM
  #45
Yea, the lock washer in your pic's doesn't look right?
Attached Thumbnails Replacing Tie Rod Dust Seal Boots-5th-gen-inner-tie-rod-pic.jpg
Old Jan 4, 2014 | 12:03 PM
  #46
faran's Avatar
Thanks so much PM.
Actually washer was exactly same as you have posted, but since I bent it, no longer look a new one.
Now I am in a BIG dilemma(I think), seems like threads inside Rack/Pinion and inner tie rod are slipping/worn out. I am NOT able to completely tighten inner tie rod into rack and Pinion. It goes in, but does not GO all the way down into it. I can see that threads are NOT even inside Rack/Pinion.
I mean, if inner tie rod threads are bad, I can just get another one, but can't do that with Rack/Pinion.
Please see attached pictures.
How can I overcome and fix this problem? Please help
Attached Thumbnails Replacing Tie Rod Dust Seal Boots-photo-1.jpg   Replacing Tie Rod Dust Seal Boots-photo-2.jpg   Replacing Tie Rod Dust Seal Boots-photo-3.jpg
Old Jan 5, 2014 | 07:59 AM
  #47
If the threads are bad on the rack.....
You could try to "chase" the threads to fix them. There may be some thread repair kits (heli-coil) that you could try......last, the rack will have to be replaced.
Old Jan 6, 2014 | 07:23 AM
  #48
faran's Avatar
Thanks so much PM, really appreciate it.
What do you mean by chasing a thread and any suggestion/advice for heli-coil?
Is it normal that these threads in the Rack go bad?
Old Jan 6, 2014 | 07:43 AM
  #49
Chasing threads is using a tap to "correct" damaged threads and enable re-engagement of tie-rod. This will work if damage is light.
Someone may have crossthreaded or inserted SAE tie-rod into metric rack/pinion.
Based on male end appearance, I would not be optimistic.
The helicoil fix should be possible, but will be difficult in tight space. I would suggest searching for a shop w/ some experience in installing helicoils to perform this work.
Old Jan 6, 2014 | 08:10 AM
  #50
faran's Avatar
I am always impressed with the knowledge you guys have, that's so refreshing.
I have a fear SAE and metric issue has happened, though I am not 100% sure on it.
I am going to start with a tap to 'correct' threads and then report back results.
BTW, is there any bond or weld I can use which can seal inner tie rod with rack forever?
If you guys have any other suggestion/ideas, please feel free to chime in.
Thanks so much for your help.
