reset timing of '83 honda
Old Nov 13, 2006 | 01:37 PM
honda123
Default reset timing of '83 honda
Great!
Would inconsistent idling cause the vehicle to have [:'(] excessive fuel smoke from the exhaust? If so, which one should I do first the timeing or the idling?
Thanks, J
Hey all
This is J and I have a '83 honda Accord I am getting ready for someone and I need to reset the timing because the distributor was moved accidentally whicle I was tuning it. I purchased a timing light but I need assistance with how to go about readjusting it.
Old Nov 13, 2006 | 02:03 PM
sir_nasty's Avatar
Default RE: reset timing of '83 honda
on the tranny there is a little opening (it may be covered by a rubber plug), start the engine and get it up to operating temp, connect the timing light to the #1 spark plug and point it at that little opening, you'll see a line in there and a point that indicates proper timing, watch that line and rotate the distributor a small incriment and you'll see the line move, adjust it so that the line and point are lined up then tigten the distributor down and you should be all set.
Old Nov 13, 2006 | 02:20 PM
honda123
Great!
Thanks, J
Old Nov 13, 2006 | 02:59 PM
sir_nasty's Avatar
it could yes.... set the timing first and then adjust the idle....
deserthonda
Feb 25, 2024 10:30 AM
Hondalover29
Jun 3, 2015 05:24 PM
3200guy
Sep 20, 2012 01:38 PM
darryltravis
Apr 25, 2006 09:23 PM
HondaLawgik
Apr 16, 2006 04:19 AM
