Is Rust Normal?
Have some rust inside the calipers. The car is from somewhere up north and im in Texas.. Just wondering if I should replace them soon or if this is normal. Thanks in advance.
If the rust is inside of the cup (piston), then it should be fine.
I would probably remove the caliper pins. Clean up the grease, and use some silicone paste on them. That will help them to slide back and forth properly.
Cool thanks. And when I do decide to change the calipers how difficult is it on these cars?
The front calipers are easier than the rear. The front involves removing one more bolt to disconnect the brake hose from the caliper.
The rear isn't too bad. You just have to remove the e-brake cable from the caliper as well.
I would only replace the calipers if they fail.
Wow. Im Dumb. Let me reask this whole question... I'm actually asking if it's ok if the rotors have rust inside of them. Can't believe I dot the 2 mixed up =/
Its pretty standard for rotors to rust where the pads don't rub.
The rotors are hard to remove because Honda decided to do hub over rotor, so you have to remove the hub to take the rotor off which is a pain.
Thanks. Ya I saw a video on how to do it and it didnt seem to hard but did seem harder then my last car
As the inside of the piston is exposed to weather, there would be formation of rust on the piston. There is nothing to worry even if the rust is formed on the rotor. If you want to change the calliper just go for low price Honda Accord Brake Caliper.
MessAround
Jan 13, 2014 06:24 PM
ozman05
Jul 10, 2007 10:14 AM
notamechanic
Aug 16, 2006 08:54 AM
