Is Rust Normal?
Old May 13, 2012 | 06:12 PM
94ex915's Avatar
Almost A Senior Member
Default Is Rust Normal?
Have some rust inside the calipers. The car is from somewhere up north and im in Texas.. Just wondering if I should replace them soon or if this is normal. Thanks in advance.
Old May 13, 2012 | 07:04 PM
If the rust is inside of the cup (piston), then it should be fine.
I would probably remove the caliper pins. Clean up the grease, and use some silicone paste on them. That will help them to slide back and forth properly.
Old May 13, 2012 | 11:01 PM
94ex915's Avatar
Cool thanks. And when I do decide to change the calipers how difficult is it on these cars?
Old May 14, 2012 | 12:17 AM
The front calipers are easier than the rear. The front involves removing one more bolt to disconnect the brake hose from the caliper.
The rear isn't too bad. You just have to remove the e-brake cable from the caliper as well.
I would only replace the calipers if they fail.
Old May 14, 2012 | 01:09 AM
94ex915's Avatar
Alright thanks much. Ya I was reading on some other site that they were a little more difficult then most cars but it cant be that much harder. I appreciate your help
Old May 14, 2012 | 05:57 PM
Calipers are no problem......rotors on this gen, well they are a PIA. If you are going to have this for a while I would look into the ROH conversion.
Old May 14, 2012 | 07:41 PM
94ex915's Avatar
Wow. Im Dumb. Let me reask this whole question... I'm actually asking if it's ok if the rotors have rust inside of them. Can't believe I dot the 2 mixed up =/
Old May 14, 2012 | 08:13 PM
Its pretty standard for rotors to rust where the pads don't rub.
The rotors are hard to remove because Honda decided to do hub over rotor, so you have to remove the hub to take the rotor off which is a pain.
Old May 15, 2012 | 01:03 AM
94ex915's Avatar
Thanks. Ya I saw a video on how to do it and it didnt seem to hard but did seem harder then my last car
Old May 16, 2012 | 05:49 PM
94ex915's Avatar
Originally Posted by johntaps
As the inside of the piston is exposed to weather, there would be formation of rust on the piston. There is nothing to worry even if the rust is formed on the rotor. If you want to change the calliper just go for low price Honda Accord Brake Caliper.
Thanks!!!
MessAround
Jan 13, 2014 06:24 PM
ozman05
Jul 10, 2007 10:14 AM
dbrs0821
Sep 17, 2006 11:58 PM
khedairys5
Sep 16, 2006 08:43 PM
notamechanic
Aug 16, 2006 08:54 AM
