Service engine light won't reset.
Old Dec 21, 2011 | 03:40 PM
jfralph's Avatar
Default Service engine light won't reset.
Sorry about such a lame post, but I have a problem with the Service Engine Light not resetting. Recently my light came on, I drove it a couple of weeks until I could quordinate with a buddy who has an OBD-II reader. We ran the code, I believe it was a P0457 which the reader said was a loose gas cap. The cap was checked, the code erased, but the light did not go out. Thinking I may have an issue with an air leak in the system, I rechecked for codes and found none. Still the light will not go out. Any suggestions.
Car is a 2005 I-4 auto LX with 75k miles.
Old Dec 21, 2011 | 04:52 PM
Code persisting likely means the problem was not resolved. It could be a damaged gas cap (worn out or damaged oring, or cracked cap). It could be a rust pit has damaged the fuel filler neck or vent tube.
Diagnostics will be necessary to confirm the code, and pinpoint the leak.
Old Dec 21, 2011 | 08:59 PM
The service engine light is not the same as the check engine light. Does the trouble code still exist if you hook it up to the OBD-II reader?
Refer to the owner's manual regarding the turning off the service engine light, if maintenance has been done. If you don't have the owner's manual, let me know and I will post that section.
Old Dec 22, 2011 | 10:56 AM
jfralph's Avatar
Redbull 1, that would be great if you would post that. I purchased the car used and didn't get an owners manual. I need to order one or talk to my neighbor, his wife has the same car.
Thanks.
Old Dec 22, 2011 | 11:24 AM
Here are the pages (attached) to reset the maintenance required indicator (if that is the light you are referring to).
I believe if you register at the American Honda site, you can also download a copy of the owner's manual.
Attached Thumbnails Service engine light won't reset.-maintenance-required-indicator.jpg   Service engine light won't reset.-maintenance-required-indicator-2nd-page.jpg
Old Dec 22, 2011 | 12:49 PM
scomstock55's Avatar
the service engine light will come on when the computer tells it the car needs an oil change...so once you get it extinguished it will come on again eventually.
Old Dec 27, 2011 | 11:43 AM
jfralph's Avatar
Thanks for the info. I had just changed the oil about 500 mi. before the light went on, now I have about another 1000 miles on it (1500 total). It probably needs to be reset. Thanks for all the help and input.
Much appreciated!
Makes a lot of sense, most new cars have an oil change indicator!!! Duh, sometimes I even amaze myself at how dumb I can be.
Old Dec 27, 2011 | 12:34 PM
And here is the web address where you can get the owners manaul....
www dot ahm-ownerlink dot com
derekcentrico
Sep 1, 2009 11:32 AM
elderfoster
May 25, 2009 02:44 AM
mracman1
Apr 10, 2009 02:01 PM
nancyjanes75
Nov 5, 2008 05:21 PM
GELewis
Oct 3, 2008 11:02 PM
