setting timing
Old Feb 17, 2008 | 09:21 PM
hondadude's Avatar
Default RE: setting timing
ORIGINAL: bbarrow79
WELL i AM AFRAID OF BENT VALVES ALSO BUT WONT KNOW TILL i CAN START IT.
100% FALSE Statement
Old Feb 17, 2008 | 10:31 PM
HondaDude - What is the best way to determine if the valves are bent before you would pull the cylinder head?
Old Feb 18, 2008 | 12:09 AM
bbarrow79's Avatar
fast honda how do you check then. so I can check while I am waiting for my part
Old Feb 18, 2008 | 01:31 PM
If the belt is already broken, or out of time, look at post #10 at this link.
https://www.hondaaccordforum.com/m_1.../tm.htm#108012
Old Feb 18, 2008 | 06:46 PM
It makes it much easier to rotate the crankshaft carefully, if you remove all the plugs so no compression strokes to overcome. Easy is the operative word, very easy.
You can have the valves and piston tops remotely inspected w/ a borescope inserted through the spark plug opening. Many shops will have a borescope. It may be hard to see slightly bent valves. I had 5 bent vaves, but only one was bent enough to be readily seen w/ a borescope view.
Old Feb 18, 2008 | 07:00 PM
hondadude's Avatar
First quick check is to remove the valve cover and look for a way way superloose rocker clearance.
Move the crank so the pistons are 1/2 way up the cylinders; then remove all the spark plugs; next turn the cam [as in valve adjustments-cam lobes at 4 'O'clock and 7 'O'clock]so that each cylinder has closed valves and use a tight fitting hose in the spark plug hole to blow in a good lung full of air.
You'll feel the pressure of good valves seating,and no pressure of bent valves.
the_skin_eater
Mar 29, 2009 08:03 PM
kris_loehr
Dec 2, 2008 08:40 PM
live2rice
Apr 30, 2008 10:38 PM
Slowaccord
Aug 22, 2007 06:37 PM
Philthy
Mar 14, 2007 03:47 PM
