Sponsored by:
Sponsored by:
Is side mirror on 2006 Accord heated?
Old 02-04-2017, 02:46 PM
Tony1M's Avatar
Default Is side mirror on 2006 Accord heated?
It's been quite some time since I've last posted. Good to see my timing belt thread is doing so well.
I'm back because my neighbor has an '04 Accord and it needs two outside mirrors. The OEM mirrors are heated, so I'd like to get heated replacements.
One of the current candidates is a pair from an '06 that has a V6 engine.
My questions are very simple.
Does every '06 with a V6 have heated side mirrors? If not, could you please provide a photo of what the mirror control on an '06 looks like and, specifically, please point out the switch or whatever that turns on the heat?
Thanks very much for the assistance.
Tony
Old 02-04-2017, 03:25 PM
The switch to heat the mirrors should be on the driver's window controls near where you electronically adjust the mirrors.
When I try to find identical parts, I go to hondapartsnow.com and enter the donor vehicles information, find the part I'm looking for, then write down the OEM part number. I do the same for my vehicle. Identical part numbers will definitely swap.
If the part numbers are different, then I'll look at some of the components to find out what is different. The actual mirror is part number is different between the 03-05 vs the 06-07. Some of the other stuff is the same.
You can also click on the part number and it will list the vehicles it will fit. hondapartsonline.net displays all of the vehicles, where hondapartsnow truncates the list, so this should help.
Old 02-04-2017, 03:34 PM
Tony1M's Avatar
Thanks! Below is a photo my neighbor just took of his '04 mirror control. Notice the heated-mirror extra portion to the left of the ****. Does an '06 that has heated mirrors have the same switch?
Old 02-04-2017, 04:47 PM
Did the same search on part numbers for the switch and they have a different part number. The 04 ends in A01, the 06 ends in C01. Likely slightly different.
Old 02-04-2017, 05:03 PM
Tony1M's Avatar
Thanks again.
Old 02-07-2017, 09:37 AM
Tony1M's Avatar
My neighbor bought the '06 mirrors. In short, they are perfect replacements for a small fraction of the price that Honda wants for new mirrors. As a reward, my neighbor treated my wife and I to dinner yesterday evening.
Thanks again, PA.
Old 02-07-2017, 06:15 PM
No problem. Glad you posted the results. I figured they would work. I just wasn't sure what the difference was between two mirrors with different part numbers.
balsam12
01-12-2016 04:05 PM
vanle2009
11-08-2014 08:34 AM
iimzii85
11-01-2010 01:16 PM
ndp
06-07-2009 05:23 PM
yoggi
02-01-2008 07:51 PM
Quick Reply: Is side mirror on 2006 Accord heated?
