Size of External Torx bolt on upper transmission mount 2011 Accord 3.5L
I am in the process of replacing all 5 engine mounts on my wife's 2011 Accord. I have the passenger side, front and rear active mounts installed. The upper transmission mount under the air filter has a external torx bolt and I am trying to find out what size the external torx bolt is. In the shop manual it states: NOTE: Do not remove the TORX bolt (B) from the upper transmission mount. If the TORX bolt is removed, the upper transmission mount must be replaced as an assembly. I guess Honda wants to sell you the aluminum mount and the engine mount in tandem. I thought this would be the easiest mount to change. The largest External Torx star socket set I could find is E24 on Amazon. I don't mind buying the sockets if I know I have the right size. Appreciate the help of any experienced DIYer.
slickgeek
May 17, 2014 08:03 PM
