motor mount
Old Jul 5, 2011 | 08:03 PM
patwguinness's Avatar
Default motor mount
I am replacing the passenger side motor mount on my 2000 Accord 3.0 Vtec. On the center bolt that goes through the mount there is some kind of counterweight attached by rubber to a little bracket hanging from the head of the bolt. The counterweight itself is about the size of a Zippo cigarette lighter and about the same shape. The rubber that holds the weight to the little bracket is rotted and is just about to let the weight fall off. Is this counterweight very important? I looked all over the web for one and couldn't come up with anything, so it's probably an expensive dealer part! I'd just as soon get by without it if I can. Thanks for any help on this, guys. Never seen anything like it before.
Thanks,
Pat W.
Old Jul 5, 2011 | 09:11 PM
You're probably referring to the side engine mount dynamic damper.
hondapartsnow.com/genuine/honda~damper~side~engine~mount~50808-S87-A80.html
Old Jul 5, 2011 | 09:13 PM
I assume it is #4 in the picture. It is $32 at the dealership. Usually the part is installed for a reason. I don't know what would happen if it was missing.
Old Jul 12, 2011 | 03:40 PM
phastlt1's Avatar
I also have a 2000 v6 accord...in the diagram, is #2 a transmission mount?
thetangstr
Aug 28, 2012 11:26 AM
baer77
Feb 27, 2009 03:47 PM
trvlnut
Oct 30, 2006 02:16 AM
Yangster
Sep 5, 2006 08:28 PM
Markus26
May 17, 2006 09:28 PM
